dennislanier
Nov 03, 2015Explorer
TenOC wrote:dennislanier wrote:
Also, did you (or could you) drain the water heater. If not then you need to make sure there is antifreeze in it also.
My water heater does not have a "drain" so I remove the aniod rod and replace if a new one (if needed) in the spring.
I think the anode rod (or plug is some cases) IS the drain for the water heater. Maybe some of the newer ones have a separate drain that I am not aware of.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
