NMDriver
Jun 26, 2015Explorer
I never put mine all the way up, not because I think it will help in an accident but because it takes a long time and I do not like to hit the top of the worm gear with the leg nut. I generally use the manual leg extensions and only use the electric for 5-6 inches of travel to unhitch and level up.
I do not worry about the 5er falling off behind the truck. I do worry about it trying to come through or ride up over the back of the cab in an accident :(
I do have a bed saver and it has saved my bed twice. Once when I parked on a bunch of prairie dog holes and the legs sank into the ground after I started to pull out from under the hitch and once when I failed to engage the pin lock before doing my pull test. Real learning experience....Always do a pull test and always check the ground you are parked on.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
