cchristanis's avatar
cchristanis
Driving with landing gear partially extended?
I tried doing a search on this but only found stuff on landing gear that doesnt answer my question. So, I have a torque 301 5er TH and was wondering about this. If there ever was an emergency and the TH disconnected from the hitch wouldnt it prevent major damage to the TH by having the landing gear partially extended or even fully (not that I would do that). I know the breakaway will apply the brakes but the front of the rv is going to drop and have some damage without a doubt especially at higher speeds. There is no way the gear is going to catch something in the road being extended a little bit. I have an andersen ultimate aluminum hitch by the way and absolutely love it! I have safety chains too but Im working on getting a different way to cennect them to the bed cause my Ram came with the 5er prep and the hooks are squareish. The safety chains dont connect to the hooks without adding something in between. I have to remove the ends and put different ones on. Here are pics to explain:
http://www.amazon.com/Andersen-Mfg-Ultimate-Connection-Safety/dp/B00J6ZGWXY
https://www.etrailer.com/p-RP30145.html
  • Besides when 5vr comes disconnected it smashes the truck bed and tears up the tailgate........landing gear will not be of any saving benefit.
    IF you are really concerned with 5vr disconnecting........get a 'bedsaver'
    It is a safety catch device that captures 5vr king pin should 5vr come unhitched and stops damage to truck
    Bedsaver
  • kaydeejay wrote:
    There is a good chance the landing gear would simply fold under the front of the TH. Then what will you have gained other than bent landing gear!
    X2, I don't have a 5er, but I agree with the above post. If you have that much mass moving it isn't just going to stop and drop on the landing gear with out folding the landing gear over. JMO
  • There is a good chance the landing gear would simply fold under the front of the TH. Then what will you have gained other than bent landing gear!
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 19, 2026
