myredracer
May 21, 2017Explorer II
As long as the rotted holes aren't large enough to poke a finger through, I'd move the light up/down or left/right a bit, drill some pilot holes and re-attach. Use a little caulk in the old holes. Some Proflex around the light will help it stick too. But may depend on type and size of the light.
Matchsticks will work sometimes because they're fatter than a toothpick. Can be shaved as needed with a sharp knife. As mentioned above, epoxy could be a good option.
Never use silicone caulk on the exterior of an RV...
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
