Towin_Toys
Aug 10, 2017Explorer
mkirsch wrote:pickup is within a half inch front to rear as when unloaded
I *think* you mean that the heights are within 1/2" of UNLOADED height, not within 1/2" of each other, but just in case you meant 1/2" of each other, you need to know that that is no longer the way to adjust a WD hitch.
Modern WD hitch adjustment deals exclusively with the front ride height only. Depending on the age of your truck you would bring the front end back down to unloaded ride height by adjusting the WD hitch (older) or between halfway and all the way back down (within the last 5 years). Rear ride height is irrelevant.
Correct, within 1/2" difference of UNLOADED weights front to rear. The unloaded front ride height as measured was 42-3/8". Loaded it is 42-5/8" so 1/4" higher loaded than unloaded.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
