Slipp
Nov 23, 2018Explorer
Towin Toys wrote:Bobbo wrote:Slipp wrote:
The bottom line is this trailer is ment to haul toys, and we do not haul a toy.
You hit the nail on the head with this sentence. That trailer is intended to have a significant weight in the back to counter all of that tongue weight. Unless you get the tongue weight down to 12% to 15% of the trailer weight, nothing else will work.
How much air pressure are you keeping in the air bags while towing? Also, how many full links of chain visible at the end of the Blue Ox tow bars when hooked up and tensioned?
I've tried varied combinations. 6-7 links of chain visible, from the end. 15 lbs of air to get the rear above the upper overloads. I've aired up to 60, but found that 30psi is about right.
Any thoughts on more or less tension?
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
