Water-Bug's avatar
Water-Bug
Explorer II
Feb 08, 2015
Dual 30 Amp Service
This is a topic that I haven't seen discussed here, although it probably has been. I am planning on installing an RV electrical outlet at my home. Running the wiring for 50 amp service can get expensive, if you go any distance. I actually don't anticipate the need for 50 amp service while parked at home. Installing a two legged 30 Amp service terminated with a 50 Amp socket seems to be a reasonable compromise between a single legged 30 Amp RV circuit and a true 50 Amp RV service. That would give me twice the power of a 30 Amp RV outlet and run nearly everything in my RV. I realize that the home 30 Amp breaker would trip befor the 50 Amp RV main, but I could probably run both ACs which usually can't be done on a 30 Amp RV circuit. Am I missing anything here? As long as the wiring meets code for a 30 Amp circuit and I use a 30 Amp breaker, I don't think it violates any elecrical codes. The sockets are rated for maximum current, so I don't see an issue with putting an over rated socket on a circuit. Am I missing something?
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 07, 2025
