I bought a old style (U-Bolt) dual cam setup. I was installing it and noticed that where the second bracket goes is in the steel propane tank base. So I measured it up and drilled some holes through...
Thanks, the bottom piece is bolted on, I will unbolt it and then run it through the nuts like you said, I just didn't think about that. I thought I would have enough clearance in the first place, but it was really close.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
