mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
For a 6" wide A frame sure looks like what you have, you need a 1" hi rise tow ball with the Reese HP trunnion bar head.
JBarca wrote:
The hi rise tow ball "must" be stamped on top for the full GVWR of your camper or larger. Check that as some hi rise tow balls have very low ratings while others can be 25,000# goose neck tow balls.
JBarca wrote:
Here are some limitations. You are doing well using the floor jack however there are other limiters in this. Shank length and TT front end design.
JBarca wrote:
See here. This is a measured 74 deg left turn. 90 degrees was mentioned and that is not going to happen on a TT with a 50 degree inclusive angle A frame.
JBarca wrote:
Your goal is to adjust the hitch the best you can and not have it be the binding point in a hard left turn. Pending the shank length and TT design, the tail light can crash into the camper before the hitch binds. Shorter shanks crash faster but offer a level of being slightly more stable. Longer shanks allow more degrees of turning to not hit the tail light but then the LP tanks are there.
JBarca wrote:
A 74 degree left turn going forward may be all the turning radius of your truck can do any way.
JBarca wrote:
Backing up on the left side, well you can crash something and it may be the LP tanks with the bumper. There is also so much a conventional WD hitch can do in regards to turns. 74 degrees is good. You start going a lot past that and you going to break something in the hitch.
JBarca wrote:
So that is optimizing a left turn. The right turn with your ball coupler will be limited to 65 degree right. See here. The friction sway bar arm is going to hit at 65 degrees. There is not a lot you can do about that. And "most" times you turn sharper left than right so it often is not a problem.
JBarca wrote:
I see you have shimmed out the cam arms with attempts of making the WD bar mate better with the cam. I have done this. You can see it here on my older camper
JBarca wrote:
However in my case I had square corner channel iron A frame and you have to shim out the frame plates so the bend radius of cam frame plate does not bind on the square corner of the frame. Even some tight radius tube frames may need a washer.
JBarca wrote:
What you need to do is mark the left and right WD bars and always use them on the same side. Over time they will wear to be a perfect match between the cam and WD bar.
JBarca wrote:
Now to the emergency breakaway switch, this should be set with the proper saftey chain length. This topic can get as much attention as gas verses diesel... See here for how I came to do this and why.
WD Hitch Safety Chains Hook Up (Pic's)
JBarca wrote:
Your 2 style hitch heads. You have the older 3 piece welded head and the new 1 piece all cast head that replaced it. The all cast new head has a higher boss for the tow ball to give more ball nut clearance and a high ball platform to help with binding. The Hi rise tow ball does this on the older 3 piece style.
JBarca wrote:
If you have a very loose fit between the shank and head on the all cast head, call Reese and they will send you a free shim is needed. Do not just tighten up the head trying to spring it closed. I have not seen or heard of any recent heads cracking like the once back in the early 2,000's which where before the 3 piece welded head. It seems Reese worked through what ever the issues were.
JBarca wrote:
Oh and yes, like Barney says, set up the WD with the DC on. No need to set it up on the chains then start all over when you add the DC. I have set up many DC's and WD from the get go. It's not a problem. Don't know where you heard or read that as it seems out of context.
JBarca wrote:
Hope this helps and good luck.
