mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
Odds are high you will be up against rear axle/receiver issue on loaded TW before you reach 10,000# loaded camper. Floor plan and where you can put gear drives the TW. I may have missed it, what year/model is the camper? I can look up the floor plan and see if I can tell any loading attributes in relation to TW. We happen to be a rear living layout folks and once that floor plan is loaded, they can be very tongue heavy.
JBarca wrote:
A good question is what should be used as "level"??? I have found on several campers and longer is sometimes worse, the main frame is rigid over the axles, bows down from the axles to the front header and then the A frame can be uphill or down hill. And the frame behind the axles may bow down. I have found going inside the camper with a 2 foot or longer carpenters level on the floor just ahead of the axles is a good happy medium place to declare camper level. If you want to get real nervous, pull a string tight along the main frame rail and see for yourself. A new unloaded camper is normally better than a full loaded one.
