mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
Nice layout! I have seen this before, the Keystone Bullet has one similar. Tracking yours down I believe it is this one.
http://www.coachmenrv.com/products/freedomexpress.aspx?page=floorplandetails&floorplanid=4884
JBarca wrote:
A heads up, I do not know what size tires and load range you have on the TT, when you get fully loaded a good thing to do is get individual wheel weights and try and get ideally 20% extra reserve capacity in the tire.
JBarca wrote:
I hope that you where setup on high enough capacity tires from the get go. If you are over weight on one wheel for the tire, you will need to shift gear.
JBarca wrote:
I will add this, just as a friendly head up. The camper is 35 feet long and you have the ability to reach 8,500 to 9,000# without too much effort. The loaded TW ideally is sitting up at 13%, and 15% is better for that size camper. You are doing a good job at trying to optimize the Reese DC. You will need too on a camper of this size. The EX most likely will benefit from the upgrades I pointed you too. If after optimizing it out, TT, hitch and TV, truck tires and you cannot obtain stable towing, research Hensley and Propride hitches. I have a buddy who had a 05 EX and a 34 ft Jayco and he went DC to hensley, however tires played a roll too for him.
JBarca wrote:
Yes, parallel to the ground is what is meant.
