mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
Several Open Roads forum members have gone to through wall bolting on tube frames with a backer plate on the inside to prevent tube crush. Turk2500 has done this. He has pics of it, I'll see if I can find them. A search may turn them up.
JBarca wrote:
If the ends of the A frame rail tubes are open one member, Fisherguy, created a tap plate, a plate with 2 nuts welded on it and he then slid that down the open frame tube to hold the nut inside. He has pics on here as well.
JBarca wrote:
While in your case, lack of grip or torque may well be the cause, if the DC frame plate is not dead tight and flush to the bottom of the A frame rail, this can and will allow the frame plate to rock around causing the problem and pulling on the screws. I thought you used a C clamp when setting up, so I'm thinking the self tapping screws are not going to cut it on your rig.
JBarca wrote:
Think forward to converting to bolts. Sooner or later they will rear their ugly head again.
JBarca wrote:
Also in case you did not know, on 1,200# and heavier TW's, is is best to bolt on the snap up brackets as the C clamp snap up setup has been known to spring open in turns.
JBarca wrote:
PS. How was camping in the new rig!
