mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
Reese Tech Support wrote:
Suggest kit 58507.
Reese Rivnut Install Instructions wrote:
1. Place the dual cam bracket on the
frame at the correct spot for your
installation. See dual cam instructions.
2. Use the long ½” bolt to clamp the
bracket in position.
3. Using the holes in the bracket as a
guide, drill two 7/16” holes into the
frame.
4. Remove the bracket and drill the
holes out to 11/16”. Do not ream out
the hole. This needs to be a snug fit.
5. Put the Rivet Nuts into the holes in
the frame.
6. Place the bracket over the rivet nuts,
thread the ½-13 x 1-1/2 hex head
bolts with lock washers into the holes.
7. Tighten the long ½” bolt against the
frame, ½ turn after contact with the
frame.
8. Tighten the ½” bolts on the outside of
the frame.
9. Torque to 75 ft. lbs.
