mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
No. 3 2 small bends at the top of the DC frame plate. OK which way is the bend? If the A frame rail bowed in or bowed out? It could be either way and you did not state. This answer really helps tell a good part of the story.
JBarca wrote:
AND did you make a real hard left turn that could of approached the 76 degree or greater area?
