mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
TUCQUALA wrote:
I have read other posts before that say "when in a turn all the WD lift is applied to one snap up" and I politely disagree! The bars have two almost equal bends, and when one is going forward, the other is moving back and has to be applying an almost equal force to its snap up. I would bet that if there were a method of measuring that force, the 2 would be very close.
TUCQUALA wrote:
Just another thought, if there weren't a space on the inside between the snap up and the frame, I believe that there would be almost no occurrences of bent snap ups and frames, with the possible exception of bar to head or bar to cam arm jamming. Maybe Cequent should make a different snap up for the common frame width on today's trailers, or some sort of filler to spread the load.
TUCQUALA wrote:
That is one reason I am leaning toward the new bar paint against a rough cam (and probably not the same wear area) causing the excessive forces when the snapping or banging occurred.
