mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
It is a fact that making a turn with a conventional WD hitch where the truck and trailer wheels are on different surface angles changes the hitch head tilt in relation to the trailer A frame. If the trailer wheels are on level ground and the truck on a surface that on angle (say 5 or 10 degrees for example) in relation to the TT, the hitch shank in the back of the truck is going to follow the truck and the hitch head with the tow ball in the coupler will pivot the WD bars. The hitch head movement will change the loading on the inside and outside turn WD bar. How much it will change will depend on the angle and the head tilt of the hitch.
JBarca wrote:
On the DC, since the chain does not swing like a non DC WD hitch it is easier to spot that the inside turn WD bar can totally unload in spring force. And it does not take very much angle between the truck and trailer. I have seen it and measured it in my own driveway.
JBarca wrote:
On the non DC hitch the chain attached to the WD bar will swing towards the TT. Since it is attached to the WD bar, it is harder to see that inside WD bar unloading. And it may take more angle difference between TV and TT to go to zero load, however the load is still significantly reduced because the hitch head is titled in a force unloading direction.
