mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
In light of this new realization, if it holds water that is, you will have to retrace you total trip in your mind on where did the truck riding surface create any level of back flex and did it come with a compound angle turn at the same time?
JBarca wrote:
We know the damage occurred on the drivers side of the TT. You or I really need to know the amount of level or uneven ground and which turn direction was the kill shot that created the high WD forces. Or there where several turn events. Pending the amount uneven ground you drove on I can build a case for a left or right turn doing this.
