mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:It was a Reese 1200 lb HP round bar syatem. The first one was the second generation type with the gold colored cams. When the bolts for the cam ripped out of the trailer frame, Reese replaced the entire hitch with a newer third generation system (silver colored cams) because the mount holes for the cams are in a slightly different location. Needless to say, the same thing happened. I worked very closely with Reese to try and work this out and even you tried helping me out. Neither of the 2 sets of bars I had were with any bulges or imperfections. I even ground a little steel off one set at the top of the detent anyway. My original instal had level bars. I tilted the head up so the bars would be angled up and I tilted the head down so the bars would tilt downward. Nothing ever worked flawlessly. Every time I got to a destination or home, I was always wondering what that hitch would look like. The first time I noticed the binding (where the cam was jammed in the detent and lifted up with slack in the chain was at a dump station and I was turned maybe 20 degrees from center on level ground. I used the snap bracket bar to bang on the cam a little and it became unbound to the detent. It didn't seem like there was much downward force on it. The force was definitely pushing outward against the outside lip of the cam. The bolts holding the cam to the frame were loose once it let go.Campin LI wrote:
I had binding issues with my old dual cam setup. Sometimes the detent on the inside bar would not unlock from the cam on a turn. This put a lot of outward pressure on the outside lip of the cam. When this happened, sometimes the cam would lift up leaving slack in the chain because the cam was lodged into the detent. It would eventually let go and make a real loud bang. When this happened, the bolts that hold the cam to the frame would become loose or tear out. Sometimes on not so tight turns, when the detent of the bar was jammed onto the cam, I got bent snap bracket from the outward pulling of the chain, maybe 25-30 degrees off vertical alignment (on edit - maybe less of an angle than this). I did eventually get tired of trying to stop the problem and I switched to Equal-i-zer brand hitch. The commonality was that the bar did not unlock from the cam and it was related to binding. I could never get rid of the binding. No matter what I did, the instance of binding was just moved to another location. I think a lot may have to do with the slop between the hitch and the receiver of the truck. I also think the angle the bar makes on the cam plays a role. There is a lot to analyze. I also think the stiffer bars are less forgiving.
Hi,
Did you have the HP DC or older standard DC with the U bolts holding it to the frame?
And what capacity WD bars?
The older standard DC in some cases had WD bar flare interference with the newer 1,200# WD bars. And the newer HP DC had flare issues too as I posted just above.
Thanks
John
