mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
mrekim wrote:
I need to tow the trailer before getting it fixed. It's somewhat local - a couple of trips within a 50 mike radius.
I'm not hooking up the dual cam, just WD bars. I was going to use my 800 lb bars since I don't need to swap chains around, etc. If I don't adjust the head, the bars will be at 8 or 9 links. Is there any problem with that, other than ground clearance?
