I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
I think the repair is the easier part. Finding the cause is the hard part. Enough force was added to your frame to bend it. If you make that stronger, the next weekest part will bend/break. My guess is that your cam arms will bend. On mine the frame did not bend, only the bolts tore out. Over time, the cam arm did bend, so after your repair, I'd keep an eye on that.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
