I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
Dealing with the radius on the frame mount was a bit of a pain:
This is supposed to be an implementation of this "no drill" solution to beefing up the install:
The studs are 1/2" grade 5 bolts with the head cut off. One side is 1/2-13 and then when I did the 2nd one I decided to do 1/2-20. The studs for the snap up will be 1/2-20 as well. I may try to get away with just the top stud for the snap ups.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
