mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
In reviewing all this, I would expect that the high chain force in that turn buckled the frame at the setscrew of the snap up first. Then snap up then bent. Once the snap up bent, then the chain hangs a lot farther out and pulls on the DC arm in a twisting motion. When the high chain force that bent the snap up pinch bolt area developed, that high load created very high friction in the DC. As the turn progressed that friction dragging force went up the cam arm to the A frame. Since the cam arm was being twisted by the outward handing chain, the combo of both them bent the DC frame plate mounting area of the A frame which may have been aggravated by the flat washers behind it creating a localized point load.
