mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:John, there've been a couple times when I posted opinions about trying to use only the deflection at the rear end of a WD bar as a measure of load on the bar.
---I know there was a post as I recall you helped point out the error that could occur with the way I did it. At the time I could not think of how to hold the end of the WD bar rigid enough and then just preload the end of the bar.---
