mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
This is "different". What you mean "teardrop" replacement?
JBarca wrote:
The bracket on the left where the main frame plate is made from 2 parts welded together is something new, well to me anyway.
JBarca wrote:
Then this different 2 pieces welded frame plate has the cam arm clevis tabs favoring the "inside" of the A frame. What year and when you get these?
JBarca wrote:
What bracket(s) where you using when the TT frame bent? And were both the left and right made from the same method? (all 1 piece or 2 pieced welded)
