I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
It is hard to tell if the centerline of the threaded shaft to the end of the cam lobe is different. While they may have several molds to make these, you can tell by the outer radius on the cam lobe boss is radius's different, can't tell for sure if the center line distance is different. If it was, this would also move the chain closer to the frame and possibly bind on the WD bar. I'm "assuming" they did not change this center distance.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
