mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
mrekim wrote:JBarca wrote:
3. Another factor not yet discussed is hitching up. Mrekim when you hitch up do you flip the snap up's real easy either by your hand or gently pressure on the pipe OR do you pull full weight of the spring bar with the pipe to snap up? What do you do tongue jack during snapping up?
I raise the tongue and use the pipe. It's not much effort to use the pipe.
Was the bent chain plate on the left side of the TT where all the big damage or on the right side where only the bottom of the frame bend in?
Just the driver side - side with most damage.
