mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:TUCQUALA wrote:
OK, John, I have a stupid question!!! I have the early gold yokes ('04 purchase) and when adjusting, easy to tighten up inner nut before cinching down the outer nut. But how in **** do you adjust the length of the cam if you can't rotate the inner nut as you stated!!??? The keyway would prevent the cam from being turned, and I'm sure you aren't supposed just let the inner nut float on the threads!
Maybe if one was right in front of me, I could understand what you are saying, but I still can't see how the cam can be adjusted if the inner nut can't be "spun".
H'mm not a stupid question. Your right. I'll dig some and report back.
They may have relived the inside of the yoke so the corners of the nut allow it to spin and I miss-spoke. (it happens...) The pic was not clear enough to see that detail.
mrekim may be able to clear this up quick, can you spin the upper nut when it is agasint the yoke?
