mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
JBarca wrote:
Ron,
Another question/topic: Did I understand your last statement correctly. For a 500# downward starting force from the TT acting on one WD bar, this translates into a 2,170# at the WD chain due to the increase from the breakaway friction load of the turn? And if so, is this then a 2,170/500 = 4.3 to 1 linear increase in WD chain load per pounds of down force? If linear, is it then if we have 1,000# downward force (fill in the number as needed) from the TT do we end up with a 4,300# WD chain load in a turn from the breakaway friction force riding up the cam?
