mrekim
Sep 19, 2013Explorer
Dual Cam Setup
I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
mrekim wrote:Yes, that's correct -- except my example had the bar being lifted by 1/4" rather than 3/4".
I'm trying to make sure I understand. Your increase from 1000# to about 1075 above is just the chain tension force due the the bar being tensioned more due to an additional 3/4" distance. This part I understand, it's just like tightening up the chain by 1/4 link.
Then when sway occurs, there's some additional (large?) friction force that occurs as the bar tries to climb the 45 degree bend at the end of the bar. This force only occurs during motion (sway or turning) Is that correct?Friction force occurs whenever there is a force on the bar which tries to make the bar move relative to the cam.
If yes, then during sway does this friction occur on both sides since for a small angle the spring bar is climbing the cam on both sides?Let's assume the TV/TT angle is zero and both cams are perfectly centered. Each cam will be in contact with both the front slope and the rear slope of its bar.
