I'm working on setting up a new Reese Dual Cam setup. I think I need a 1" extended ball, and wonder if I would benefit from a 2". Here's are some photos of where I'm at now: Side view, I think...
I realized that putting the measurement on the bracket would be a problem as the spring bar moves the reference point will move.
I glued on a little reference. This shows the unloaded height. Lines should be at 1/4" intervals so this is at 1 3/8". The lowest line looks like it may be off vs the others so at some point I'll need to check it:
Here's a photo loaded on the TT. It looks like there's 1/2" left. I'm going to have to reset the pointer higher:
Here's the distance of the pointer:
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
