NCMODELA's avatar
NCMODELA
Dual cam vs friction bar
Hi, I took the trailer out this weekend and had a wonderful drive at 60-65 mph. No sway at all. I have a Reese round bar setup with 1000 bars. I had a Tractor trailer pass me at 80-85, it pushed me and the th about 2 ft off the road. But it did not oscillate. When a long line of cars passed it did the same thing. It only happened twice on a 6 h round trip.
I need to purchase a sway setup. Is there advantages with going with the dual cam over the bar. What would be better for this issue?
Thanks Bill
  • Equal-i-zer and Reese DC are both good hitches. The Equal-i-zer is easier to setup. I have the DC because that is what my dealer stocked.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    The difference is the DC has "built in" sway control rendering the add on friction sway devices unnecessary and inferior.
    Another good setup is the Equalizer Hitch which I currently run after graduating from the old EZ Lift setup with add on single friction sway control. I went with the Equalizer over the DC due to the design of the tongue on my new V Hull trailer. Both the DC and Equalizer are good hitches. You might want to add a friction control to your rig and see if it alleviates your concerns.
    If not, scrap your current set up and go with one of the better hitches with built in sway control. FWIW, I ran the old EZ Lift setup with single friction sway control for about 9 years and it worked "OK". The Equalizer Hitch is like night and day.
  • The following is MY opinion and MY personal experience with both designs. (Seems I have written a long response, many apologies)
    The BEST sway control is a properly loaded and designed trailer, a Proper Tow Vehicle, and a properly set up and matched WD hitch. Sway control devices are supplemental and should NOT be used to correct a sway problem in the design.
    Dual Cam Sway Control is a good design. So is Friction sway control .... when used appropriately (Meaning if you are over 25 ft you use TWO bars, no exceptions. If you are over 25 ft and do not use two bars then its not a fair comparison, DC is superior in this instance because the Single bar is being used outside its design parementer)
    In my experience DC and Friction bars are on par with each other within their design parameters. I presently own both and found no difference between Dual Cam and Dual Friction sway bars as far as seat of the pants towing is concerned. I mean, no sway is no sway.. no wiggle from passing vehicles is no wiggle.
    Hooking up is a little bit longer with Dual Friction bars, so dual cam wins there... by about 60 seconds.
    The BIGGIE for me is that if I get in a bind with friction bars, I can just take them off. (tight maneuvering, etc.) If you get in a bind with Dual Cam you can grenade your WD hitch.
    Now, I am NOT fear mongering or spewing some regurgitated garbage, I personally experienced a hitch failure while using Dual Cam. A Dual Cam hitch must be set up 100% correctly as to prevent binding.
    I personally choose to run Dual Friction bars.
    Here are some additional reasons why I choose not to run DC.
    1) The WD bars are NOT attached to the Trailer with a DC. You can lose a WD bar by turning too tight and pulling the bar out of the cam. Rare, yes.. but it does happen.
    2) Any weakness in the hitch will be exposed by the Dual-Cam in SPECTACULAR fashion.
    3) If you lose WD you also lose sway control
    4) Not every dealer handles, stocks, or understands Dual Cam Sway Control... this is a biggie if you have a malfunction on the road.
    Friction Sway Control strengths
    1) Effective
    2) low cost
    3) Replacement parts are available at every RV dealer in America and Canada
    4) Removable
    5) Not dependent on WD At all. (If you have a WD hitch failure, chances are you can still run your friction control)
    Now the Friction bars are not without their weaknesses
    1) The need periodic adjustment as the brake material wears down (quarter turn of the tension bolt occasionally)
    2) They need periodic cleaning with a wire brush
    3) They exert a constant level of tension, they are not reactive or proactive. They are just what they are, a dampener and a device to significantly increase the stiffness between the hitch head and the trailer coupler.
    Now, I said that DC is a good design, I stand by that. I also stand by the statement that a friction sway control is a good design.
    OP, your mileage will vary, and I hope that you gained a little insight from my experience.
    Jeremiah
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    BarneyS wrote:
    I too have had both and agree with Scott.
    Barney
    x3
  • I've had both and the Dual cam is head and shoulders above the friction setup.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
