DrewE
Mar 29, 2019Explorer III
lastword wrote:
I will stay with 120v at 7amps.
I'm also looking at making a relay that will hold the compressor off when the refrigerator or microwave is starting. Something that monitors the amp draw/power coming into the RV. When a threshold of amps is drawn by something the control circuit/wire to the compressor is held open (compressor off or wont start). Make the threshold settable.
Assumed usage:
Microwave 5 amps
Refrigerator 3.5 amps
Ductless ac 7 amps
so about 15.5 amps when all is running and assume 2x when it tries to start
As long as more than one thing does not start within a few seconds of each other all is swell!!
Thoughts?
The microwave will use more power than that; the oven's wattage rating is output power, and AC power consumption is at least a couple hundred watts more. Most these days are at least 900W or so output, so 10+ A. There's no appreciable extra startup surge for a microwave.
3A for an RV fridge is about right (and again no startup surge). A residential fridge uses a lot less running (1A or less) but more when starting up or defrosting.
The starting power for the mini-split air conditioner might not be much if any more than the running power, since the units typically use a variable frequency inverter motor drive circuit. It definitely ought to be much less, relatively speaking, than a standard RV air conditioner.
Don't forget the converter or inverter/charger, which if the batteries are low can be consuming several amps as well.
I would not worry too much about automatic load management for a 30A power source. Many 30A RVs (mine included) have an air conditioner and a microwave, and many people (myself included) use them simultaneously without trouble if there are no other major loads. For a 15A connection, probably just turning the thermostat off before microwaving would do the trick and not need anything in the way of fancy wiring.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
