carringb
Jan 26, 2016Explorer
Sounds about right. My trailer has 12,500 GVWR and I went with 1500 bars. I'm pretty much made out on them. I probably could have gone with the 2,000# bars but it's good enough as long as keep towing with my dually.
The only hiccup I had was the shank didn't have enough radius on the corners to fit my receiver! I had to borrow the dealer's grinder to knock them down to fit. Luckily the remaining powder coat hasn't chipped off. If it ever does I'll just get it re-coated. That was summer 2014 so maybe they've fixed that problem. I also have a very heavy duty class 5 receiver (20k) so the inside radii of the main tube may be larger than on lower class hitch receivers.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
