MitchF150
Jan 26, 2016Nomad
I should expect no more then 1,500lbs of tongue weight, so I should get the system that handles 10,000lbs and 1,500lbs TW. Correct?
Your factory hitch on the F150 is only rated for #1150 TW with a WD hitch, so not sure how you figure you can go to #1500??
Unless you upgraded your factory F150 hitch?
Good luck!
Mitch
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
