Aadkins101
Apr 21, 2014Explorer
Electric Broom
Need recommendations for a lightweight, inexpensive electric broom. Don't mind if it uses bags, but if not, need one that is easy to empty without spilling the contents all over the place!
rockhillmanor wrote:
After wasting a ton of $$$ on the stick brooms, I finally found a vacumm that is lightweight, small enough for an RV and actually WORKS!
...you have to look for the amps the vacuum puts out. Amps provide the power to actually pick up the dirt.
...I was VERY shocked that the ones you are lead to believe are the most powerful? Had the lowest amps of all of them!
