boshog's avatar
boshog
Electric Trailer Brake Question
I am new to RVs and recently took possession of a new Montana 3790RD fifth wheel RV. The 3790RD is rated at 13K pounds dry and the CAT scales gave me a trailer axle weight of just under 11,000 pounds. The RV has dual Dexter 7,000 pound axles and both axles have electric brakes. My tow vehicle is a 2015 RAM 3500 Cummins with rear air suspensions and factory brake controller. I have the truck/RV set up level. I also performed the brake adjustments on the RV and found the brakes adjusted properly.
I do not feel the trailer brakes are working properly, that is, I do not feel a great amount of braking effort from the trailer. I have the brake controller set to heavy brakes (as opposed to light <10K lbs) with the gain set to the maximum. On a gravel road, manually applying full electric brakes, the RV wheels will not lock up, all I feel is a slight drag. There is no braking effort difference felt if the RV brakes are hot or cold.
This is my first experience towing a heavy trailer. I have an 18 foot flat bed trailer I use for towing my tractor, around 7200 pounds, and the brakes on the flat bed trailer will lock up.
How much braking effort should I expect from the trailer brakes of a 13,000 pound RV? Should I be able to lock the wheels on gravel? Am I experiencing normal braking for this weight? Before I talk with Chrysler or Keystone, I want to know what to expect from the brakes, it is possible they are working as designed. Thanks in advance for any input.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
