LOFAT36's avatar
LOFAT36
Electrical outlet
The outlet for the fireplace in our 5er is dead. I've tested all breakers, fuses and the rest of the receptacles and all are fine. Everything else works. Broken wire to the outlet perhaps ? Any ideas ?
  • The outlet can be bad. Did you check the wires hooking into the outlet to see if they are hot? If they are then it is the outlet.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
