docnascar's avatar
docnascar
Emergency exit window
On my Coachmen 18bh they put an emergency exit window in the back. Unfortunately, you can't open it (It clearly says "Emergency EXIT only!") the same way as a normal window does. It has a screen (which I don't get) :?
Seems to be a hinge on the top and the window pushes open. To open it, you have to push a bar that you unhook and push outward to open the window.
Just curious... is it ok to open these for normal use or are they a one time use since it says "Emergency EXIT only."
This is it...
Its the back window.
You can see the bar.
**Updated the pictures with my camper. I realized I have the frameless windows.
