docnascar's avatar
docnascar
Emergency exit window
On my Coachmen 18bh they put an emergency exit window in the back. Unfortunately, you can't open it (It clearly says "Emergency EXIT only!") the same way as a normal window does. It has a screen (which I don't get) :?
Seems to be a hinge on the top and the window pushes open. To open it, you have to push a bar that you unhook and push outward to open the window.
Just curious... is it ok to open these for normal use or are they a one time use since it says "Emergency EXIT only."
This is it...
Its the back window.
You can see the bar.
**Updated the pictures with my camper. I realized I have the frameless windows.
  • Be very careful the first time you open it -if it says EXIT ONLY its likely one designed to fall out when opened to allow you to climb out.
  • The rear window on mine clearly states that it is for emergency use only and is not hinged. The whole window, frame and all, falls out for easier and faster exit. I've been told that if you try, you'll likely never get it properly sealed again. Mine is as wide as the queen bed, and I imagine its pretty heavy, but I've resisted the temptation to try it out. All the other windows open just fine.
  • docnascar wrote:
    What do you use to lube the seals?
    Is it ok to use normally during camping if it can be propped open?
    Our rear emergency exit operates as a conventional crank out style with separate emergency release latches that allow the full window to open. Every couple of years I pop the latches and lube the rubber seal with dry silicone sprayed on a rag.
  • Yes it is just a window that can be used as a escape route use it any time and as often as you want....
  • What do you use to lube the seals?
  • Those windows should be opened from time to time to insure they don't stick shut if needed. Clean and lube the rubber seals to insure easy opening.
