- path1ExplorerI don't know which is better as far as door window and frame but....
Don't be surprised if you find silicone sealing the window on the inside. Maybe that's why so many leak? Took long time to get out all old stuff. Wasn't sure what type of silicone to use as I don't like any of them. Finally went with what Winnebago uses on their exterior of RV's and has used it for years. Big difference in 3 buck a tube and stuff that was around $14.00 a tube. - Chris_BryantExplorer IIBoth are cheap plastic- this is really a time to bite the bullet and spring for the EDWIN.
If that is out of the budget- both Elixer and Valterra are identical, so which ever is cheaper. - IAMICHABODExplorer IIIIf you are going to replace it then maybe do it up Like This
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
