ericpatt's avatar
ericpatt
Equilizer vs. Blue ox SwayPro?
We're leaving on a long trip(16+hrs) in a couple weeks. Currently have an equilizer hitch with 1200# bars. TT is a Salem 30KQBSS towed by a 2012 Surburban 2500. The equilizer works pretty well but I still get a little sway with heavy cross winds or when a semi passes. Usually cruise 65-70mph. Was thinking I needed bigger bars(1400#) to eliminate the sway. Called dealer and they advocated for me to switch to a Blue Ox Sway Pro. New bars are $2-300. New blue ox is close to $800.
What would you do?
Trailer dry weight is 6900#. Tongue weight, unloaded 900#. Loaded, I'm thinking it's closer to 8500# and 1200 tongue although I've never had it weighed. When connected, the truck & TT are level so I don't think its a set up issue...
Thoughts?
  • All- Thanks for all your input. By sway, I mean, when I semi passes me or cross wind, I'm getting sucked into the semi or pushed around a little. It usually resolves quickly, but having to continually worry about semi's sucks. Don't get me wrong, I'm always checking my mirrors anyway but not knowing how much I'll be sucked into a semi sucks.
    For further clarity, I have leveled the front of the truck and from friends conversations, it sounds like that's also not helping. Having the truck lowered this week and hope that it helps.
    If it's just a quick nudge and then immediately settles down once past, that's normal and nothing to worry about.
    Just hold steady. Try not to crowd the left lane. The closer you are, the more you will feel the bow wave. If you do feel the need to do something, gently ease to the right but no jerky movements.
    This is where the premium hitches separate themselves from the others.
    There is no holding steady, or moving over, no easing over. You no longer have to prepare for or anticipate the passing 18 wheelers in anyway.
  • With a Surburban you are catching more wind with your vehicle than a pick up does. Make sure your socket bolts are torqued to spec and check them every few hundred miles.
    x2. My towing experience felt the same with the HA and towing my previous 5th wheel. Rock solid.
  • Does anyone have recommendations for where to purchase the Hensley or ProPride with a discount? I need a hitch to eliminate sway similar to what the OP described but the price of these options is quite high!
    They are often found for sale used. As a prior owner I would not hesitate to buy used. However if I never owned such an expensive hitched. I imagine I would be reluctant to buy used.
    Buying new gives you the benefit of the money back guarantee and possibly financing incentives.
    I was a very satisfied customer but I will admit I was a reluctant skeptical buyer.
    Yes they are expensive but they do work as advertised.
    Friction based hitches do not compare.
    Thanks — I’d likely want to go with a new one for peace of mind. I hadn’t looked into financing incentives, so maybe there are some options with that. Thanks!
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
