rk911 wrote:
ryegatevt wrote:
I'm making this a new post, but referencing a a previous discussion on exiting in a fire.  In our Class B we have 4 exits:  driver's door, passenger door, cabin door, and rear van doors.  We cannot understand how a vehicle the size of a Class A can have only one door!  Many folks are not physically able to dive out of a window emergency exit and could easily become trapped in an emergency.  And as a driver I could not live without the ease of getting in and out of a driver's door.  If we did ever look at "upsizing"  I would never look beyond a Class C for the exit door reason alone, as appealing as some of the Class A features might be.  Any comments?
many Class A's have a std or optional driver's door...which does absolutely no good if a fire occurs while the occupants are in the rear sleeping area.  just as most apartments have but one entrance it's a calculated risk.  our home has three exits...a front door, patio door and rear door...none of which would help us should a fire break out while sleeping.  also a calculated risk.
Most building codes require an egress window in all sleeping areas of a home.  If you think it is too difficult to get through an egress window I would suggest building a ramp or something to aid in the egress.  A large percentage of home fires are at night when the occupants are sleeping.
I have a 36 inch dresser that is same height as the window in my bedroom.  To get out I only need to open a drawer and I have a ladder to climb.  The drop to the outside is a little rough but the alternative of burning I will take a broken leg or what ever any day.
Same goes for my 5th wheel.  I have had the wife practice opening the egress window as I have also done.  The 5th wheel is a longer drop but when possible I park the truck with the truck bed below the window.
