Flatfive's avatar
Oct 28, 2020
Exploded Battery!
Last night around 9 PM, we heard what sounded like a gunshot. Went out and looked around. No clues. This morning I see that one of the two 12V batteries on the tongue of my 20 ft trailer had exploded! It's continually being charged by a good quality, computer-controlled converter so It shouldn't have been being over charged.
Just yesterday, though I did disconnect the cables one at a time and clean the connections with sandpaper. Then I replaced them, again, one at a time, and greased them so as not to get corroded again. I did this because the batteries were running only 9 volts even though they were connected to the converter for a month. I was figuring they couldn't get charged through the corroded connections.
Any clues as to what the problem is?
  • Did you check the water level in the batteries while you had them disconnected? My guess is the exploded one had a low cell and the charging made it spark internally.
  • Shorted cell - boom!
    Replace the other battery also. Might be eductional to have it load tested but it's toast.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 23, 2026
