jimj's avatar
jimj
Explorer Sport Trac not comming out of neutral tow
I tow a 2005 Sport Trac and normally when I disconnect form the motorhome I turn the key off and put the transmission in park so that the neutral tow disengages. Recently it has been hanging up in neutral so any gear is in neutral. I put it in 4wd low to engage the trans and it engaged very hard.
I don't know where to look for the problem.
If anyone has had this problem please let me know how you solved it.
Thanks
JimJ
  • JoeH's avatar
    JoeH
    Explorer III
    JimJ
    On my F150 and previously on my Ranger, I have to turn the key ON
    , then move the shifter to Park. Need to have the key on to provide power to the xfer case shift motor
  • this truck uses a encoder motor on the transfer case could be the motor or transfer case. remove motor and see if you can move gear in transfer case.the motor is bad
