69_Avion
Dec 28, 2013Explorer
falconman wrote:
If your tapping before the regulator be sure you are using high pressure hose.
That is a fact. I tapped "after" the regulator with quick disconnect fittings and valve and I had a custom hose made. The company that builds the hose that I used will only build hoses with the high pressure hose material. They are concerned about people mixing them up. It works for me, but it is a little heavier.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
