ajboudreau's avatar
ajboudreau
Extended Cross Country Travel
My wife and I are thinking about purchasing a new rig. We are debating between a 5th wheel and a Class A. We are planning to take several extended trips and hit many sites across this great nation. For those of you out there, which is easier to get around those scenic routes? I'm concerned about traveling some of those long winding roads like Pacific Coast Highway. Thoughts?
  • My wife and I have the same thoughts and talked for over 20 years about traveling around the USA. I researched trailers for about 8 months due to the fact that we already had a tow vehicle. We purchased a 33 foot Grand Design Reflection 5th wheel in January. We started our travels in March and have put 5000 miles on the unit since then. So far our longest trip was up to LaConner Washington, about 2000 miles round trip. We hit 101 in Napa and took it all the way to our destination in Washington. You can only be the judge of what type of RV will work best for you. With trailers the most important thing IMO is having the proper/safe tow vehicle. It must be able to deal with the weight and size of the entire rig under all condition. In either case you will have upwards of $100,000 tied up so do a lot of research, this and other forums are a treasure trove of information. Look at all your options. This is one of the most fun parts of the process. Don't be in a hurry and don't be pressured. Good luck and safe travels.
  • AJ,
    Your question has a lot of merit. Unfortunately, nobody can give you a real answer until you nail down the rig size. That just makes all the difference in the world.
    We have an old tiny class A that we take anywhere we choose to go and don't need a towd.
    It is all your call. If you can't think of anything that pushes you one way, rent or borrow something.
    Matt
