John_Wayne
Apr 26, 2014Explorer II
You should have a relay that lets the house batt. charge when driving that would keep the house batt. charged even if it is wired wrong. If not get a relay hook a wire from the starting batt. to one of the big posts on the relay from the other big post on the relay run a wire to the house batt. Then a wire from ignition switch that is hot only when the engine is running to the small lug on the relay. And it should solve your problems even though your rig is wired wrong.
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: May 28, 2026
