falconbrother's avatar
falconbrother
Explorer II
Feb 14, 2018
EZ Lube axles/hubs
I bought my TT in 2017 and it has the EZ lube hubs, but.. When I bought it the RV mechanic that gave us the walk around was emphatic that we shouldn't mess with those hubs for a few years. He discouraged even squirting grease in them. I pushed him a little on that and he said that people regularly blow their seals out by trying to service the hubs. He said that if I wanted to I could maybe do one squirt a year into the hub. He also said, don't fool with them for ten years. Just tow it and don't worry about it.
As a guy who has owned a few old Harleys with tapered roller bearings, and having personally repacked them at every new tire change, I'm really not comfortable with his instructions. I have pulled it for a few trips and the hubs are always cool. But, what's the point of EZ lube axles if you don't need to squirt some grease in there every once in a while? How can grease in a hub/bearing blow out a seal unless it's under pressure? There shouldn't be any pressure in there as a bead of grease will let you know you're done.
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: Apr 30, 2025
