cobra98's avatar
cobra98
F150 Towing Problems
I have a 2014 f150 145" wheel base with the 5.0 V8, 331 gears, brake controler and 20" wheels. It has the tow package. Tow cap is 8000lbs. I just bought a 27 ft TT with a dry weight of 5800lbs. 700lbs TW. Installed the E2 round bar 10,000lb wd and I still having problems with sway. What are the best upgrades I can make to improve towing. I was thanking airbags might help or a heavy duty shock. Is there a good f150 tow tune out there for better power. The sway wasn't bad but not good either. I measured the front and back of the truck and both were at 36". The TT is level also. I was thanking maybe I don't have the tongue weight right. At 70mph the truck stays in 4th at 2800 rpms and will sometimes go into 5th on flat ground. Is this to much trailer for the truck.
  • MORE TRUCK!
    There really is noting you can do or add th your existing truck.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
