Grangrey4's avatar
Grangrey4
Fiberglass roof and uv protection question
Winnebago class c fiberglass roof, was thinking of putting a uv protectant on after wash. Does anyone know if you can use a spray on? Manual only references washing with mild detergent does not mention using anything else.
  • I just treated mine with a fiberglass restorer & then'coated' it with Turtle Wax 'Ice'. I can't imagine not maintaining the gelcoat on my coach be it on the sides, back end, or roof. Gelcoat is stuff that requires periodic maintenance or else it will go South way sooner than it would otherwise if maintained.
    Over the years I've had tremendously good luck with the 'Ice' line on all the gelcoat boats I've owned. Using it from top to bottom now on my coach & will continue to do so.
    Remember if you use anything carnabua based on the roof it will not 'seal' the gelcoat & thus it will return to a chalky surface again in relative short order unless you use a sealant. Also something interesting about carnabua I recently learned is that it burns off at a relatively low temp (as in well below the ambient temps most areas of the U.S. see in the summer) so even though many swear by it being the best shine on the planet, if you live anywhere that it gets hot out the stuff will burn off... sometimes within days if it's really hot outside.
    YMMV but for me I'm taking the hour or so once or twice a year to apply a coat of sealant on my fiberglass roof.
  • Keeping it clean and waxed is an OK idea (but I would never bother waxing).
    If you don't the gelcoat will get chaulky. It doesn't cause failure but it doesn't look shiny and you may get streaks down the side as a result. Once it gets chaulky, it's harder to bring back the shine and the shine lasts a shorter period of time...but I really don't care if it's shiny.
  • I am in the southeast and we have been baking! Just want to take care of the roof. First Winnebago and first fiberglass roof. Manaul has only cleaning methods no uv protection to keep it in good shape in this heat.
  • I don't see that it would do any harm except maybe make the roof a little slippery.
    I spray 303 Protectant on the sides of our 96 Southwind after it's washed. I would not hesitate to use it on a fiberglass roof.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
